简介
Mustard from that corn dog. Your dripping morning coffee. Toothpaste. Stains happen! Many people believe that once a garment has a spot on it, it's time for the wash—but this isn't always true. By spot-washing and re-wearing your garments, you create less wear-and-tear on your clothes and the environment.
This guide will walk you through the process of washing a spot out of a garment. Have a tricky stain? Check out our Stain Removal page for the proper cleaning agent.
工具
配件
无需配件。
Examine the stain. Determine what cleaning agent you'll need using our Stain Removal page. For general dirt, use a gentle, low-chemical liquid laundry soap.
  • Examine the stain. Determine what cleaning agent you'll need using our Stain Removal page. For general dirt, use a gentle, low-chemical liquid laundry soap.
  • Hold the garment over the sink and rub a small amount of your cleaning agent into the stain with your finger.
  • If you are dealing with a tricky stain, follow the instructions on the Stain Removal page linked above.
添加评论
Using a toothbrush, gently work the cleaning agent into the stain.
  • Using a toothbrush, gently work the cleaning agent into the stain.
  • Use an up-and-down motion with the brush—tapping the stain with the bristles—as opposed to a back-and-forth motion which can damage the fibers of the garment.
  • If you are working with a knitted garment, such as a sweater, do not stretch the garment as you are cleaning it as this can cause warping of the fibers.
  • Work the stain out of the garment. If the stain isn't releasing, check out the Stain Removal page for help on your particular stain.
添加评论
  • Rinse the spot throughly with cold water.
    • For quicker drying, try to keep the water contained to a small area surrounding the stain.
  • If you are working on a knitted garment, such as a sweater, do not use hot water as it can shrink the fibers. In general, cold water is better for cleaning garments. The water from your sink is not hot enough to sanitize garments, so cold water works just as well.
添加评论
  • Lay a towel out on a waterproof surface.
  • With the wet area facing up, place your garment on the towel and allow it to dry.
添加评论
终点
6等其他人完成本指南。
Brittany McCrigler
于2012年03月05日注册
79,187 信誉积分
创作了134篇指南
团队
iFixit iFixit 的会员
Community
107 名成员
创作了6,510篇指南
添加评论
浏览统计数据:
过去的24小时: 11
过去的7天: 59
过去的30天: 451
总计 12,132
