简介
The day-to-day washing and wearing of sweaters causes piling, or balling and fraying of the fibers that compose the sweater. Pilling is visually unappealing, but more importantly, it can lead to additional fraying of the garment. By removing the pilling you can help lengthen the life of your favorite Patagonia sweater. And we all know that old sweaters are the coziest.
配件
无需配件。
Lay the sweater flat on a table. Identify the pilled area of the sweater. It will be covered in little balls of fuzz. Grab your sweater stone. If you ever forget how to remove piling, there is a handy diagram on the back of the box.
  • Lay the sweater flat on a table. Identify the pilled area of the sweater. It will be covered in little balls of fuzz.
  • Grab your sweater stone.
    • If you ever forget how to remove piling, there is a handy diagram on the back of the box.
添加评论
Working along the grain of the sweater, gently brush the sweater with the sweater stone. As you use the stone you may notice a funny smell, that is a natural part of the stone which is released as it crumbles away. You will also notice small pieces of debris, as the stone cuts away pills it also breaks apart slowly. Simply shake out the sweater when you are done to remove debris.
  • Working along the grain of the sweater, gently brush the sweater with the sweater stone.
  • As you use the stone you may notice a funny smell, that is a natural part of the stone which is released as it crumbles away. You will also notice small pieces of debris, as the stone cuts away pills it also breaks apart slowly. Simply shake out the sweater when you are done to remove debris.
添加评论
Lift the sweater stone. To prevent snags, always lift the sweater stone when changing directions.
  • Lift the sweater stone.
    • To prevent snags, always lift the sweater stone when changing directions.
  • Brush the sweater stone the opposite direction along the grain of the sweater.
添加评论
Continue brushing until the pilling is removed. Clean your sweater stone by rubbing your hand across the stone to removing the lint.
  • Continue brushing until the pilling is removed.
  • Clean your sweater stone by rubbing your hand across the stone to removing the lint.
添加评论
终点
5等其他人完成本指南。
Brittany McCrigler
于2012年03月05日注册
78,597 信誉积分
创作了433篇指南
团队
iFixit iFixit 的会员
Community
113 名成员
创作了6,002篇指南
I also have used a disposable razor to shave pills and fuzz off of Patagonia sweaters and capilene - it worked really well. Just lightly run it down the sweater. If any fuzz is persistent, do the same but perpendicular to the first direction you used. It made my sweater and capilene pants look like new again!
AE3 - 回复
Great post, and I want to recommend you a page of Fabric pilling test, which may help you a lot.
Cynthy Lee - 回复
添加评论
浏览统计数据:
过去的24小时: 9
过去的7天: 73
过去的30天: 274
总计 14,804
