简介
Do you have pants that need hemming but don't have a sewing machine to do it? Use this guide to help you hem any type of pants without using a sewing machine.
Wear the pants and fold the hem up until you get your desired length.
  • Wear the pants and fold the hem up until you get your desired length.
添加评论
Remove the pants, making sure that the folded hem remains fixed.
  • Remove the pants, making sure that the folded hem remains fixed.
  • Lay the pants down on a table and measure the length from the original hem to the folded edge.
    • Make sure to take note of all of your measurements.
添加评论
Turn the pants inside out, and unfold the folded edge.
  • Turn the pants inside out, and unfold the folded edge.
  • Starting from the original hem, measure out the length of what will be your new hem.
    • The length you will need for this step would be the length you measured out from the previous step.
  • Using your fabric marker, draw a line marking where your new hem would be.
添加评论
Starting from the line you just created, measure out 1 inch and mark with a line.
  • Starting from the line you just created, measure out 1 inch and mark with a line.
添加评论
Using the 1 inch line as your guide, cut off the extra fabric.
  • Using the 1 inch line as your guide, cut off the extra fabric.
添加评论
Fold the raw edge up to the new hem line. Fold it again  along the new hem line,  so that the raw edge is now inside the fold.
  • Fold the raw edge up to the new hem line.
  • Fold it again along the new hem line, so that the raw edge is now inside the fold.
添加评论
Place a sewing pin parallel to the fold to make sure that the fold stays in place. Fold and pin all the way around to create your new hem.
  • Place a sewing pin parallel to the fold to make sure that the fold stays in place.
  • Fold and pin all the way around to create your new hem.
添加评论
Have your needle threaded and ready to go.
  • Have your needle threaded and ready to go.
  • Sew the fold close to create a new hem; try to keep your stitches small and even.
    • White thread was used instead of black to make the stitches more evident in the pictures.
添加评论
Once you're done stitching, tie off the thread by creating a knot towards the end of the string. Cut off the excess string above the knot. Remove all of the sewing pins.
  • Once you're done stitching, tie off the thread by creating a knot towards the end of the string.
  • Cut off the excess string above the knot.
  • Remove all of the sewing pins.
  • Repeat steps 3 to 8 for the other pant leg using the same measurements, and then you're officially done!
添加评论
结论
4等其他人完成本指南。
Irish Pellas
于2015年09月29日注册
277 信誉积分
撰写一个指南
团队
Cal Poly, Team 15-5, Green Fall 2015 Cal Poly, Team 15-5, Green Fall 2015 的会员
CPSU-GREEN-F15S15G5
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 50
过去的7天: 278
过去的30天: 1,398
总计 9,861
