简介
How to re-thread a stripped or mis-threaded aluminum hole.
工具
配件
无需配件。
Determine which hole has the cross threaded or stripped screws.
  • Determine which hole has the cross threaded or stripped screws.
  • Determine the size of the current thread. Threads are called out by the outer diameter, a dash, and then the thread count. For example, the tap shown is 1/4"-20".
    • The hole's outer diameter can be determined by measuring the width of the screw or bolt that goes into the hole.
    • The thread count can be determined by counting the number of threads in one inch of screw length.
  • Select the appropriate tap size.
    • Taps are sharp. Do not handle the teeth.
  • Install the tap into the tap handle (See photo).
Some steps/ bullets have periods when others don't.
Iridian Vaca - 回复
Other than what I listed above, everything else looks good!
Iridian Vaca - 回复
Reword the bullet addressing the attire necessary to wear for the fix.
Iridian Vaca - 回复
Align the tap attached to the tap handle over the cross threaded or stripped hole.
  • Align the tap attached to the tap handle over the cross threaded or stripped hole.
  • For right hand screws, insert tap into tap hole as you slowly rotate the tap handle clockwise.
    • 99 percent of of holes, screws, and bolts are right hand screws. If you know your hole is a left hand thread, rotate counterclockwise instead of clockwise.
Wouldn’t you need a left handed tap for left hand screws?
Taylor Bolding - 回复
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Rotate the tap handle clockwise two full rotations, then counterclockwise 1/4 of a turn.
  • Rotate the tap handle clockwise two full rotations, then counterclockwise 1/4 of a turn.
添加评论
Repeat step three until you cannot easily rotate the the tap handle clockwise anymore.
  • Repeat step three until you cannot easily rotate the the tap handle clockwise anymore.
  • Rotate the tap handle counterclockwise until the tap is out of the part.
添加评论
结论
After re-tapping your miss threaded check to make sure the threads work by screwing in the bolt or screw the hole is intended for
另外一个人完成了本指南。
Kevin Tremaine
于2015年04月09日注册
163 信誉积分
创作了2篇指南
团队
Cal Poly, Team 28-5, Green Spring 2015 Cal Poly, Team 28-5, Green Spring 2015 的会员
CPSU-GREEN-S15S28G5
3 名成员
创作了5篇指南
If the hole is truly stripped then the technique in this guide won't work because the hole would then be larger than it was originally and the tap won't bite into the metal and therefore not cut any new threads. So then there are two options:
1. Choose the next larger size bolt and drill and re-tap the hole to fit that larger size. Or if you really must use the same size bolt then:
2. Use a helical insert (aka "Helicoil") which is a coil of hardened steel wire that forms both a outer and inner thread.
I used option #2 to fix a stripped hole in a bicycle shock absorber. I bought the Helicoil kit sized for my bolt from a automotive supply store. The kit came with the drill bit and tap sized for the outside threads of the coil. I drilled the hole, tapped the threads, then threaded the coil into the hole. The inside diameter of the coil was sized to fit the original bolt.
Don Barthel - 回复
Don is correct that tapping the hole as it exists won't really work and offered some viable solutions. However, if there isn't enough material for a Helicoil to bite into it won't work either on a through hole and sometimes using a larger bolt isn't an option either. In such cases you can add some filler to your existing hole. JB Weld can work as a filler for aluminum. If you apply a thin enough coating, you can tap the hole after it cures without drilling - then use a Helicoil for strength. Option 2 would be to use an aluminum filler rod and a MIG welder to fill, then drill and tap the hole.
ABCellars - 回复
Another option, is to drill and tap a larger hole and drive a threaded rod into the hole, grind both sides off flat, then drill a hole into where the threads mesh and lock the two together with a locking pin, then re-drill and tap a hole to match the original. Its more convoluted, but it’ll work if a helicoil won’t work, and the replacement would be very strong.
Gaisa Sanktejo - 回复
(Added info) In my case, I had an m7 hole that stripped out, I had some m12 threaded rod, so I drilled and tapped an m12 hole, drove and locked the m12 rod in place and as mentioned above, ground both sides flat. I then drilled and tapped a new m7 hole. It worked perfectly! :)
Gaisa Sanktejo - 回复
Despite what this article says, you can't turn a right hand tap counter clockwise to make a left hand thread. You have to buy a left hand thread tap.
Paul P - 回复
添加评论
浏览统计数据:
过去的24小时: 119
过去的7天: 784
过去的30天: 3,375
总计 56,251
