简介
The HP EliteBook 840 G3 received a 10 out of 10 on our repairability scale, for all of its components are modular and accessible. Big positives include that its battery, RAM, and SSD are all accessible and removable, and the display is very easy to replace if broken.
Reference shots: packaging US4, rear and open. Reference shots: packaging US4, rear and open. Reference shots: packaging US4, rear and open.
  • Reference shots: packaging US4, rear and open.
添加评论
Standard, simple lower case removal. Remove 10 standard Phillips screws and pull up against clips. Internal view.
  • Standard, simple lower case removal. Remove 10 standard Phillips screws and pull up against clips.
  • Internal view.
There is an 11th screw in the SD card slot.
Sean Boyles - 回复
The battery is immediately accessible under the lower case. Removal is quick. The battery is held by two captive Phillips screws (no adhesive) and can be lifted out with a handy pull tab.
  • The battery is immediately accessible under the lower case.
  • Removal is quick. The battery is held by two captive Phillips screws (no adhesive) and can be lifted out with a handy pull tab.
  • Easy battery removal is a high mark for repairability, as all batteries will eventually wear out and need replacement.
添加评论
The CMOS battery is tightly glued down but can be freed with a spudger. The remaining adhesive is enough to hold the battery during replacement. We can remove the wireless card, SSD, RAM and CMOS battery with little to no effort.
  • The CMOS battery is tightly glued down but can be freed with a spudger. The remaining adhesive is enough to hold the battery during replacement.
  • We can remove the wireless card, SSD, RAM and CMOS battery with little to no effort.
添加评论
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
The (free, online) HP repair manual says to remove the keyboard before the motherboard, so we do that. The keyboard screws are labeled by size, making reassembly easier.
  • The (free, online) HP repair manual says to remove the keyboard before the motherboard, so we do that.
  • The keyboard screws are labeled by size, making reassembly easier.
  • The keyboard can be pried out after removing two Phillips screws.
添加评论
The pointing stick (keyboard cursor control) board is modular and can be separated from the keyboard, making for less expensive repair. The interconnect cable, and switch can likewise be separated.
  • The pointing stick (keyboard cursor control) board is modular and can be separated from the keyboard, making for less expensive repair.
    • The interconnect cable, and switch can likewise be separated.
添加评论
Now we remove the midframe. It's held in by three varieties of Phillips 0 screws (M2.5 x 5, M2.0 x 7, and M2.5 x 2.5) — 26 in total. Without documentation it'd be tough to know precisely which 26 screws are securing the midframe due to it's spread-out design.
  • Now we remove the midframe. It's held in by three varieties of Phillips 0 screws (M2.5 x 5, M2.0 x 7, and M2.5 x 2.5) — 26 in total.
    • Without documentation it'd be tough to know precisely which 26 screws are securing the midframe due to it's spread-out design.
    • Luckily, HP's got us covered by providing a service manual for this device.
  • Removing the next component, the heat-sink/fan combo is more straightforward. Its six screws are numbered to indicate order of removal. This simplifies reassembly.
添加评论
After removing screws and disconnecting cables, the motherboard is ready to slide free. The display connector has a convenient tab for handling, making the delicate re-insertion procedure simpler and safer. With the screws removed, the motherboard is easily removed from the lower case.
  • After removing screws and disconnecting cables, the motherboard is ready to slide free.
    • The display connector has a convenient tab for handling, making the delicate re-insertion procedure simpler and safer.
  • With the screws removed, the motherboard is easily removed from the lower case.
  • Unlike some notebooks that have separate I/O boards for DC-in or an SD card reader, all ports except a USB and VGA live directly on the motherboard.
    • This design feature means that if any ports break (as heavily-used power jacks are likely to), you'll need to replace the whole motherboard or perform board-level repair to fix it.
添加评论
Lower palmrest peripherals are comprised of: The trackpad, which is secured by grounding tape and Phillips 0 screws. The smartcard reader assembly (including status LEDs),  secured by Phillips screws.
  • Lower palmrest peripherals are comprised of:
    • The trackpad, which is secured by grounding tape and Phillips 0 screws.
    • The smartcard reader assembly (including status LEDs), secured by Phillips screws.
    • The I/O board (USB and VGA), secured by Phillips screws.
      • Port break-out boards make for less expensive replacements of high-wear components like USB ports.
添加评论
The display bezel can be a first-out component, not requiring the above disassembly. The bezel is secured with plastic clips, prying is relatively simple, but care must be taken to avoid scratching the unprotected display. The LCD is secured with four screws and has a single display data interconnect cable plugged into the back.
  • The display bezel can be a first-out component, not requiring the above disassembly.
  • The bezel is secured with plastic clips, prying is relatively simple, but care must be taken to avoid scratching the unprotected display.
  • The LCD is secured with four screws and has a single display data interconnect cable plugged into the back.
  • Displays are high priority components in laptops as they are fragile and easily broken. A display that is accessible with minimal disassembly, and which has no peripheral components built in means a quick, inexpensive repair.
添加评论
The display frame is simply attached to the palm rest with four Phillips screws.
  • The display frame is simply attached to the palm rest with four Phillips screws.
  • The palm rest contains final peripheral components including: fingerprint scanner, speakers, and the power button board.
    • The above components are modular and not high-wear components. The power button is the most likely to fail and is reasonably accessible.
添加评论
The HP EliteBook 840 G3 earns a 10 out of 10 on our repairability scale (10 is the easiest to repair): RAM, SSD, and battery are easily accessible and removable.
  • The HP EliteBook 840 G3 earns a 10 out of 10 on our repairability scale (10 is the easiest to repair):
    • RAM, SSD, and battery are easily accessible and removable.
      • Along with the spare hard disk slot for memory expansion, the computer is upgradable, in addition to repairable making for a longer device life.
    • All moving parts, including keyboard, trackpad, and pointing stick are modular and can be quickly replaced.
    • The display is immediately replaceable, without any unnecessary disassembly.
    • All screws are Phillips #0 and #00.
    • Manufacturer provides user-accessible repair documentation and sells replacement parts.
添加评论
终点
4等其他人完成本指南。
Evan Noronha
于2015年02月05日注册
121,998 信誉积分
创作了702篇指南
团队
iFixit iFixit 的会员
Community
117 名成员
创作了5,574篇指南
添加评论
浏览统计数据:
过去的24小时: 34
过去的7天: 389
过去的30天: 1,580
总计 9,358
