简介
本指南将告诉您如何更换 Google Pixel 的电池。一般来说,手机在正常使用下18-24个月后,电池容量会显著损耗。如果您的手机不能正常充电、开机,或者经常自动关机,换块电池或许能解决这个问题。
请注意:在更换电池之前,请将电池放电至25%电量以下,如果满电的电池被不慎刺穿,会引起严重的火灾或爆炸。如果电池已经鼓包,请不要使用后文所述加热的方式来取下电池,如果需要的话,可以使用注射器向背壳边缘注射90%以上浓度的异丙醇来溶解粘胶。鼓包的电池非常危险,请注意佩戴防护眼镜,并小心操作。如果您不明白如何操作,最好交由专业人士处理。
关闭设备。
  • 关闭设备。
  • 加热iOpener,沿着边缘放置90s,以软化下面的粘合剂,或者,你也可以使用热风枪或吹风机来加热粘和剂
  • 使用吸盘拉起屏幕,使屏幕和外壳之间存在缝隙
  • 如果你的屏幕破裂,请使用胶带将其包裹,以帮助吸盘吸附,防止玻璃碎片破裂
  • 在缝隙中插入卡片
  • 将屏幕周围的卡扣撬开,切开固定他的粘合剂
This one step has broken my screen and I didn’t even manage to remove it. I suspect it was the amount of heat that was applied as the left side of the screen, the side which I applied the heat, the pixels are blue/pink instead of white. The bottom inch of the screen is black. The touch screen is sporadic, which makes the phone unusable. After about 20 minutes of applying heat with the iOpener and the screen not budging, it eventually raised enough for me to get the blue opening pick. As I slid the pick up, I notice a tiny crack forming on the screen, so I gave up at this point, not wanting to break the screen. When I turned the phone back on, I noticed the damage I’ve mentioned. So I don’t know if it was the heat, or the pressure of the pick, but the damage matches the iOpener pack.
Neil Martin - 回复
Considering the instruction says to apply heat for 90 seconds and you did it for 20 minutes, I'd say it's a safe bet you burned your screen.
Andrew Bowman - 回复
When reassembling, does the adhesive still hold the phone together when closed or do we need to apply more adhesive?
Jess Haddow - 回复
I successfully removed the screen and changed the battery. However the screen is completely broken and replacing it would me $130. A complete disaster.
Christopher Wang - 回复
This step makes no mention of how fragile the screen underneath is, and that slicing under the glass carries a real risk of screen damage. I would add it myself but the editor refuses to add a single bullet point and wants to put in an entirely new step instead. Oh, right, and I’m also out $80 for a new screen. Admittedly I should have went offsite for more comprehensive repair guides, as I would have held off on replacing the battery had I known how fragile the screen itself was, which several other guides mention implicitly.
Andrew Creeves - 回复
@franticfanatic Sorry to hear you had such a bad time. I’m actually not sure why you had trouble with the editor, but I went ahead and added a bullet with a warning as suggested, and a tip about using playing cards instead of a plastic tool—playing cards have a softer edge so they require much more patience, but they probably won’t harm the display if accidentally inserted too far. Better luck on your next repair!
Jeff Suovanen -
It was game over here for me only about 5 seconds in. Indeed the screen is very fragile and once I had heated the right side, inserted the pick halfway down the right side, then slid the pick along the bottom, and as soon ias I came around the rounded edge into the left, unheated side I heard a crunch and realized the screen was obliterated at that point. The screen no longer turns on and the phone is bricked.
Some things this article could have mentioned that might have increased my change of success:
1) Heat both the left and right edges of the phone.
2) Insert the pick such that you always move from the center outwards. I suspect my flaw was coming around the bottom from the right to the left.
3) The screen is super fragile. The warning only says don’t stick the pick in too far. Really you need to exercise a lot more caution than just that.
Benjamin Knight - 回复
Unfortunately also cracked my display on the way in. You have to go pretty deep under the top and bottom of the screen but BARELY in around the sides, especially the corners. If I had to do it over again, I would have either tried a playing card or put some type of depth limit/mark on my pick so I didn’t go more than a few millimeters in.
Matthew Jastremski - 回复
Step 1 is definitely the most difficult. Everything else is easy, I could reinstall the battery successfully, it is charging right now.
Adhesive is strong and I had to use hair dryer several times to make it softer (about 20-30 sec each time really close). So when you feel the plastic tool/card is going too hard, just heat more. I couldn’t find a playing card so used a credit card, worked fine. Also there’s much more of adhesive at the top / bottom, you have to stick the card really deep, almost to the screen itself and go back and forth several times. Anyway the most important thing is to not bend the screen too much, especially in the beginning, which is doable if adhesive is soft when heated.
Roman Shuvaev - 回复
These instructions need to require the purchase and replacement of the screen. I too broke my screen while attempting dislodge it from the bezel.
Additionally… the iOpener does sufficiently to loosen the adhesive enough to move the screen in 90 seconds.
Perhaps if the iOpener were able to encase all sides of the phone to loosen all adhesive at the same time.
Jamie Jensen - 回复
Another broken screen here, and I was trying to be extremely careful. It's just a very very delicate screen.
Renee Soronen - 回复
Another broken screen here. Followed all of the tips suggested in the comments. Now I have to replace the screen and I have no phone. What a waste.
Jeremy Keifenheim - 回复
Seeing all of these comments I was extra careful with the screen and did not crack it. but now that everything is back together the phone turns on but the screen wont work now!! This sucks.. I loved that phone!!!
Nathan Koller - 回复
I think that this kit should come with an extra screen. Sounds like most people don’t get by without breaking the screen. I would not suggest buying this kit to anyone.
Nathan Koller - 回复
使用手慢慢将屏幕从设备上抬起。
  • 使用手慢慢将屏幕从设备上抬起。
  • 小心,切勿在提起屏幕时将屏幕排线提起。
Ruined my Pixel following these instructions. Ribbon cable is at bottom (chin) of phone and not as shown in pictures. My advice take it somewhere and have them replace the battery, that way when they break it it’s their fault.
John Simpson - 回复
  • 使用螺丝刀,移除后方固定显示排线托架的3.5mm T5螺丝。
添加评论
  • 使用镊子将固定屏幕连接头的支架移除。
添加评论
  • 使用撬棒来从设备上移除链接头,然后可以完全地移走屏幕了。
  • 在使用新的粘合剂之前,请清洁框架边缘,特别注意清除任何小玻璃碎片。用高浓度异丙醇清洁粘合区域(浓度至少为90%)。
  • 在上新的粘合剂并重新密封手机之前,打开你的手机并测试你的维修。
  • 替换黏胶仅涂抹到中框边缘,但很可能涂抹的时候跑到中间。
    • 去除中部不必要的胶条,请仔细地把去除长方形中间的白胶。同时,去除白胶条之下的黑色粘合剂。
    • 仅保存中框边缘的粘合剂。
添加评论
  • 使用螺丝刀来拧下9颗固定中框的3.5mm T5螺丝
  • 设备中框一共有9颗螺丝。但是在指南展示的设备只有8颗。
添加评论
  • 将打开工具楔入位于手机左上角的缝隙之中。
  • 将开口工具滑过装置的接缝并提起中间框架。
  • 听到咔嗒声是正常的,因为卡口扣住中间框架。
  • 抬起中间框架时,小心不要损坏连接听筒扬声器和主板的排线。
when removing the mid frame i damaged a ribbon cable at the bottom left. will that prevent my phone from turning on?
Bryce Thoreson - 回复
  • 使用挑线器来从主板上断开听筒线缆。
  • 将中框从设备上提走。
添加评论
  • 使用撬片挑开主板上的电池排线。
添加评论
  • 使用镊子,撕下沿着电池的银条,露出下面的连接器。
添加评论
  • 使用撬片从主板上挑开充电口排线。
添加评论
  • 将撬片楔在电池下方,轻轻地将电池撬出来
    • 请千万小心,不要损坏或者刺穿电池。软壳锂电池,否则电池可能会漏液、起火或爆炸。请不要使用蛮力,也不能使用金属工具来撬电池
  • 电池拆下后不要二次安装使用,否则可能会有潜在的风险。
  • 安装新电池时:
    • 把手机上残余的胶水祛除,并使用异丙醇和无尘布清理该片区域
    • 用离形胶或者双面胶将新电池固定在手机上。粘胶时先把胶粘在手机上,而不是粘在电池上。胶应该围绕电池位粘一整圈,而不是仅粘在中间部分(此处为屏幕背面)
    • 用力按压电池5-10秒,使粘接稳固
添加评论
结论
更换完毕,遵循本指南相反的执行步骤,即可将手机组装好。
16等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Richard Nguyen
于2017年04月26日注册
918 信誉积分
创作了2篇指南
团队
Cal Poly, Team S23-G1, Livingston Spring 2017 Cal Poly, Team S23-G1, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G1
4 名成员
创作了18篇指南
I doubt many people can get past step 1 without it being game over. Take special care, read the comments, and other guides as well.
This is accurate. Battery replacement was successful, but my screen broke when I attempted to open it. I misjudged the dimensions of the screen on the sides of the phone and ended up breaking the LCD.
Richard Baxley -
I definitely destroyed my display trying to take it off too. For something this fragile, they should really include much more detailed instructions for how to avoid breaking the display.
vh71886 -
I broke mine too. Not the glass but the display panel underneath.
For those who are going to try opening theirs: pay extreme attention to the fact that the display panel extends somewhat beyond the bottom edge of the visible part of the display where the cable connects and, if that wasn’t bad enough, the bottom bezel has a !&&* of a lot adhesive on it. Don’t insert plastic opening tools on the bottom corners - if you do that, you will damage one of the unprotected corners of the panel like I did. If I had to do that again, I’d probably start from the top edge instead.
The new screen ended up costing me the equivalent of $80, and I was surprised I was able to walk into a store and buy one at all in a country where Pixel was never officially available in the first place. They didn’t have white ones in stock so I went with a black one.
Gregory Klyushnikov -
I have got a question, where to by a battery?
Richard Men - 回复
Hi Richard, our Pixel battery is currently out of stock, but soon you’ll be able to find it here, in our store.
Adam O'Camb -
Do you need new adhesive tape for the new battery? Why isn’t that part listed under Tools or Parts at the beginning?
Tony Curoso - 回复
Hi Tony, a new battery will need new adhesive, and our battery replacement kit comes with a precut adhesive sheet for just that. Alternatively, you can use a high-bond, double-sided tape like Tesa 61395 to secure the new battery.
Adam O'Camb -
30 min’s… id like to see that!
mischakuh - 回复
womp womp, another broken screen failure! I was so close, too. The last little wedges finally caused the LCD to have a small little crack because there was still too much adhesive holding it.
I would amend the guide to put emphasis, and/or extra time, warming up the adhesive on the top and bottom as opposed to the side edges (as that has the most surface connection).
quadmonkey - 回复
Since replacing the battery I cannot turn my phone back on at all. Needless to say the instructions did not work for me. I don’t know where it went wrong since I cannot even turn it on at all.
chika39 - 回复
添加评论
浏览统计数据:
过去的24小时: 301
过去的7天: 1,722
过去的30天: 6,984
总计 56,490
