配件
无需配件。
Carefully pop off the cover using a spudger or other opening tool.
  • Carefully pop off the cover using a spudger or other opening tool.
添加评论
Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
添加评论
Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door. Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
  • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
添加评论
Remove the door by slowly lifting straight up, put the door off to the side.
  • Remove the door by slowly lifting straight up, put the door off to the side.
添加评论
Get a new, non-damaged door.
  • Get a new, non-damaged door.
添加评论
结论
另外一个人完成了本指南。
Peterluchini
于2015年11月05日注册
448 信誉积分
创作了3篇指南
团队
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G2
3 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 23
过去的30天: 84
总计 507
