配件
无需配件。
Make sure you unplug refrigerator before beginning work on refrigerator.
  • Make sure you unplug refrigerator before beginning work on refrigerator.
添加评论
Remove the 28 mm screw holding the thermostat to the refrigerator using the JIS #1 screwdriver
  • Remove the 28 mm screw holding the thermostat to the refrigerator using the JIS #1 screwdriver
添加评论
  • Carefully remove the thermostat knob.
添加评论
  • Carefully slide off the thermostat towards you.
添加评论
  • Once the thermostat is removed, take a picture of the cords (still connected) to help with reassembly. Then proceed to disconnect the wires.
添加评论
  • Remove the three cords on the front side of the thermostat by simply pulling the plastic connector off for two connections and doing the same for the metal connection. Do the same to the back side, disconnecting another plastic connector and then remove the thermostat.
添加评论
  • Replace the old thermostat and reassemble the new thermostat using the picture that you took before to properly connect the wires.
添加评论
结论
3等其他人完成本指南。
Peterluchini
于2015年11月05日注册
481 信誉积分
创作了3篇指南
团队
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G2
3 名成员
创作了3篇指南
Peter, I have the same fridge and it never dropped any colder than 43F. Is this the same issue you were having? Did changing the thermostat fix it?
Thanks!
Krunal Patel - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 9
总计 784
