配件
无需配件。
Carefully pop off the cover using a spudger or other opening tool.
  • Carefully pop off the cover using a spudger or other opening tool.
添加评论
Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
  • Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
添加评论
  • Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
添加评论
结论
Peterluchini
于2015年11月05日注册
457 信誉积分
创作了3篇指南
团队
UMass Dartmouth, Team 1-2, Bhusal Fall 2015 UMass Dartmouth, Team 1-2, Bhusal Fall 2015 的会员
UMASSD-BHUSAL-F15S1G2
3 名成员
创作了3篇指南
That might work on the TOP hinge, but on the bottom hinge the refrigerator would have to be tilted or laid on its side. Also, you could have used a hex socket of the appropriate size instead of the “JIS #1 screw driver“ to remove the bolts.
My refrigerator is a Whirlpool that uses top hinge bolts that require an allen wrench. The bottom is another can of worms, especially with the auto-close.
The previous Whirlpool model had a bottom hinge with a plastic / nylon piece to make it close. When it broke, I made an aluminum piece that kept the door closed.
doctordon - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 9
总计 242
