简介
Simple step-by-step instructions to replace the Refrigerator Water Filter Head & Tube Assembly WR17X12203.
Disconnect the electric plug from the wall.
  • Disconnect the electric plug from the wall.
添加评论
Turn off or push down off water main valve from the wall.
  • Turn off or push down off water main valve from the wall.
添加评论
Remove the back panel with 6 screws from the back panel using a 8 mm nut driver. Remove the back panel with 6 screws from the back panel using a 8 mm nut driver. Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
添加评论
Disconnect the water supplied line from the refrigerator using two  13 mm open-end wrenches. Use a little bucket to receive the water from the water lines.
  • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
  • Use a little bucket to receive the water from the water lines.
添加评论
Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
添加评论
Disconnect the water line cover removing 2 screws  using a 7 mm nut driver. Pull up the gum seal compound.
  • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
  • Pull up the gum seal compound.
添加评论
Push the left side of the filter cover and pull it straight out.
  • Push the left side of the filter cover and pull it straight out.
添加评论
Remove the 2 screws  on top of the housing using  7 mm nut driver. Pull the housing and filter out slowly.
  • Remove the 2 screws on top of the housing using 7 mm nut driver.
  • Pull the housing and filter out slowly.
  • Remove the filter by turn it counterclockwise
添加评论
结论
Giancarlo Marruffo
于2016年09月18日注册
2 信誉积分
撰写一个指南
团队
Pasco Hernando, Team 5-1, Prince Fall 2016 Pasco Hernando, Team 5-1, Prince Fall 2016 的会员
PHSC-PRINCE-F16S5G1
1 名成员
创作了1篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 10
过去的30天: 29
总计 259
