简介
如果你忘记了密码、PIN、模式锁……
如果系统不能正常启动……
如果你想清除所有数据……
注意!!!你会丢失你所有的数据!!!
视频概述
关机
  • 关机
  • 按住电源键和音量+键
  • 出现开机动画后,松开电源键。使用音量+/-键选择菜单,开关机键确认。
  • 依次选择如下菜单
    • 擦除数据/恢复出厂设置
    • 选择“是”,删除所有用户数据
    • 开始重启系统
  • 现在重启系统
I did all of the above numerous times and still will not go past the smarttab logo
ksdiva83 - 回复
can you show more details?
刘允礼 -
结论
要重新组装您的设备,请按照相反的顺序执行这些指示。
21等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
ZFix
于2013年12月09日注册
157,324 信誉积分
创作了304篇指南
团队
Master Techs Master Techs 的会员
Community
277 名成员
创作了751篇指南
Hello! I'm trying to do what you say but I also end up at the warning sign for a custom so.. What can I do? Thanks!
PeterM - 回复
my galaxy tab 2 was fell off the floor totaly damage how to fix. pls help
tiffany decorion - 回复
Hello.Its not successfull.I follow the instruction but when i already press the reboot system now its turning off again and my tab 2 restart again.I do it many times but its still the same.how can i fix my tab?Please do help me.its been a month when i cant use it.thanks.
ilygsuper23 - 回复
Go here:
http://www.sammobile.com/firmwares/
Make a registration and find the firmware for your tablet.
In the download page you can find instructions how to reflash your tablet.
Regards.
ZFix -
My tab won't switch on its ad a new battery but still nothing is it fixable ?
paulinewhalley - 回复
I had my tab into hard reset and when I tried to select reboot system now, it didn't turn on even though I left it for how many hours. What should I do? I tried to turn it on but it keeps on going back to android system recovery.
Jaypee Ryan Culanag - 回复
I want this tab right now !! how much is this ?? can anyone tell
Klark Mances - 回复
I'm having a major issue I factory reset my tablet but now I can't download many apps I had previously downloaded it's saying not compatible with your device. I checked updates and says it's got the latest update. Someone please help!!
Amber Wampole - 回复
hi im using samsung tab a and it still keep going back after i press hold power botton and volume down. how can i fix this?
Yerkes sacuebo - 回复
i have done as directed by sammobile on downloading Odin & firmware, & have completed the download of the firmware, "I get a pass" on the Odin file but all I get is the home screen and nothing further. I've tried different firmware, to no avail. Now my home screen is also stuck in French! When I check the android man it still shows him down with an ! . Please help.
mytrinityangel - 回复
Hi there,
I believe I might have a virus issue, not sure :(. My Galaxy Note 2 tablet seems to stuck with flicking on and off Samsung galaxy Note logo. Tried the technique mention above many time it does seems to work at all. I got the android guy showing internal mechanical issue. I even having trouble power off. It's ridiculous! Please help!!!
lsuzanne168 - 回复
hello there i have a problem on my samsung galaxy tab 2 i do the procedure on factory reset and its NOT working i do this several times and its not working what aim gonna do to get back my galaxy tab working properly
romeo - 回复
Hello what I'm going to do if my anycall galaxy's is not opening menu
Alyssa Espina - 回复
Not working for me.
I get to the reboot screen, can select the options with volume keys, use the home button to select option (wipe data/ factory reset) and the selected options turns from blue to green but does nothing.
Jan - 回复
Galaxy Tab A 10.1 (2017)
Forgot password. Cannot use the gmail recovery or backup PIN. Device will not allow me to power off without entering password (which I forgot). How do I factory data reset device? I don’t need any data currently on device. HELP!
Loren Blaine - 回复
I am using Zpad X7 how can I fix black screen? The device is turn on, not but the screen is black is not displaying anything. Any help will be appreciated.
dalhatuahmed - 回复
I'm not ok with this way.
Myo Thiha - 回复
添加评论
浏览统计数据:
过去的24小时: 128
过去的7天: 865
过去的30天: 2,346
总计 185,391
