简介
Check out this guide to learn how to remove the battery pack from the Dyson DC58 vacuum. If your vacuum is not charging due to a damaged or dead battery this guide will show you how to replace it!
配件
无需配件。
Make sure your vacuum is unplugged.
  • Make sure your vacuum is unplugged.
  • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
添加评论
Locate the red lever parallel to the red trigger and on the side of the clear bin.
  • Locate the red lever parallel to the red trigger and on the side of the clear bin.
添加评论
Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
添加评论
新电池 = 运作更快的 iPhone
维修工具包价格在 $16.99
Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum. Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
添加评论
Locate the 10mm screw on the side of the battery pack closest to the purple cyclone of the vacuum Use the 2.0 Phillips head screwdriver to remove the 10mm screw
  • Locate the 10mm screw on the side of the battery pack closest to the purple cyclone of the vacuum
  • Use the 2.0 Phillips head screwdriver to remove the 10mm screw
添加评论
Locate the  10mm screw on the back of the handle on the opposite side of the red trigger button Use the 2.0 philips head screwdriver to remove the 10mm screw
  • Locate the 10mm screw on the back of the handle on the opposite side of the red trigger button
  • Use the 2.0 philips head screwdriver to remove the 10mm screw
添加评论
Pull the base of the vacuum down, away from the main body Pull the base of the vacuum down, away from the main body Pull the base of the vacuum down, away from the main body
  • Pull the base of the vacuum down, away from the main body
添加评论
结论
8等其他人完成本指南。
Krista St Onge
自 2015年09月17日就是会员了
772 信誉积分
4撰写一个指南
团队
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G4
4 名成员
10撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 89
过去的7天: 690
过去的30天: 3,292
总计 25,360
