简介
这是一个DualShock 4控制器对两个模拟操纵杆都有一个按键 相当简单的替换遥控杆,解决了这个问题。
使用Phillips #00 螺丝刀移除四颗6.0mm固定后面板的螺丝。
  • 使用Phillips #00 螺丝刀移除四颗6.0mm固定后面板的螺丝。
  • 切勿使用强力来松开螺丝,否则会造成螺纹的永久性损坏,从而导致无法拆卸手柄。
添加评论
从左肩处开始 将撬棒插入左肩来撬开一个开口 在开口处滑动来打开更多的空间
  • 左肩处开始
    • 将撬棒插入左肩来撬开一个开口
    • 在开口处滑动来打开更多的空间
    • 取下撬棒,打开手柄壳。
  • 右肩重复这些步骤。
Shoulders are where L1/L2/R1/R2 are, not the %#*@ handles. Confusing instructions.
foxhoundunit89 - 回复
Quick tip: Be VERY careful at this step not to dislodge the tiny spring attached to the L2/R2 buttons. While removing the cover, it's easy to pull off either L2/R2 button. Inadvertently pulling off either button will also remove the tiny spring as well. While not too difficult to reassemble, it's not obvious where the spring goes as the spring is almost completely hidden along the side of the button (on the inside).
I just successfully completed analog stick replacements for two controllers. I completed the first repair without any trouble but managed to dislodge (and almost lose) the spring on the second time around. Needless to say, I spent some time trying to figure out where the spring is supposed to go (no photos of this anywhere). By sheer luck, I figured it out on my own. :)
Good luck and take your time--especially the first time!
Michael Whang - 回复
couldn't have posted pics for me? :D
kimsballs -
Golden tip but I would add a thing or two.
Most probably both triggers R1&R2 will stay in lower half of the pad case with springs hanging there.
You must take them of their lower case sockets before assembly and fit them bellow L1&L2
When you feel click when fitting them and spring works like on normal assembled pad you're done.
If thats not the case do not try to assemble lower casing half as triggers will not work properly.
Simon -
if you lost the springs unfortunately, the triggers would still work but it is harder to get to the precise digital press. In other words you will have hard time to create a light press than a hard press.
meaningless -
将一个撬棒楔入壳体来打开以下按钮附近的卡扣: Share键 Options键
  • 将一个撬棒楔入壳体来打开以下按钮附近的卡扣:
    • Share键
    • Options键
  • 将控制器塑料外壳分开,注意两者依然通过排线连接。
  • 3个小模块经常从框架中跑出,为了避免损失,请保持工作台的干净整洁。
    • 2个触发弹簧
    • 1个灰色复位按钮扩展
You can't just pull the casing halves apart. There is a plastic bar that is part of the casing and separates the L1 and R1 buttons from the L2 and R2 buttons. To get this loose, pull the casing outward perpendicular to the L and R buttons until you can slide the L2 and R2 buttons from behind the plastic bar.
dzturbd - 回复
SO yesterday replaced the thumb stick on my controller, and now the R2 button is stuck, know any way to remedy this?
ScootsMcgoots -
I know you put a warning, but I lost the grey reset button extension. Any idea where to get a replacement part?
miamiman77 - 回复
Hey, not even sure when you wrote this, but wanted to share my solution for this problem. I lost one of my reset button rubber pieces when I was doing a different repair, and found that a standard bamboo skewer is just about the perfect diameter to function as a replacement. Just cut it to the proper length and you should be able to get it in there and get your reset functionality back.
tcbrekke -
You don't really need it. A long paper clip will work fine.
Ron Smith - 回复
I've removed and changed all buttons all seemed ok but now the options and share button don't work, as in when I pressed them down there is no longer a click (bounce) I'm certain it's back in the correct place and I don't think they can be put the wrong way up, does anyone have any advice please :)
Rachel - 回复
My share button stopped 'clicking'. When I stripped the controller down I noticed a small copper coloured dimple on the motherboard was depressed instead of proud like the one for the options button. With bluetack I was able to pull it out but each time I tested it with my finger it clicked once and stayed depressed. I don't think there is a permanent solution to this as it's probably metal fatigue or similar so i put a tiny bit of blue tack overy the dimple so the plunger could push that bit further and hopefully pull it out each time. Seems to work as I reassemble the controller. Fingers crossed it holds out a while! I'd love to know if someone else had a different solution.
The5HD -
I had an extra part, and it wasn’t gray. Thank goodness for the picture of the black one. It’s rubbery. The small end should be inserted down towards the gold colored spot. It’s next to the word RESET on the mobo.
J Coyote - 回复
When reassembling: If, like me, your R2/L2 buttons stayed with the bottom of the controller when you took it apart, it will be impossible to reassemble and get the tiny springs back in place.
To remedy, remove the buttons, and attach them, with the springs correctly placed, to the top of the controller. There are two tiny grooves, one on the button, and one on the controller top, into which the spring fits.
Jeff Human - 回复
Jeff, we owe you a six pack for this comment.
James Goldie -
使用手指来断开控制器两侧的主板排线。 注意排线的方向,并且在重新连接的时候确认其方向正确。 断开后,将控制器的顶部放在一边。
  • 使用手指来断开控制器两侧的主板排线。
    • 注意排线的方向,并且在重新连接的时候确认其方向正确。
  • 断开后,将控制器的顶部放在一边。
can you share the battery dimension?
luxusmirajane - 回复
使用镊子,轻轻地将镊子轻轻摇动,松开插头,取出电池插头。 在断开主板上的插头后电池就可以从控制器中提起。 匆忙移除电池可能扭坏塑料把手。
  • 使用镊子,轻轻地将镊子轻轻摇动,松开插头,取出电池插头。
  • 在断开主板上的插头后电池就可以从控制器中提起。
  • 匆忙移除电池可能扭坏塑料把手。
For the replacement battery I found that the Turnigy 2000mAh 1S 1C Lipo w/ 2 Pin JST-PH worked perfectly while also being a budget option at only $2.54 USD before shipping. However ONLY INSTALL AFTER CHANGING THE POLARITY OF THE CONNECTOR, this can be done with a pin or craft knife with relative ease. After doing this the controller has doubled in battery life. It required no modification to the controllers internals only extra care to ensure the longer cables didn’t get pinched in reassembly.
Ryan - 回复
用十字#00螺丝刀拆下电池固定器下面的单个6.0 mm十字螺丝。
  • 用十字#00螺丝刀拆下电池固定器下面的单个6.0 mm十字螺丝。
  • 切勿用力拆卸螺丝,因为它可能导致螺纹的永久性损坏,使得螺丝变得不可能拆卸。
Hello. I got a new graffiti controller (without hardware) and i wanted to switch my parts in the graffiti one. I have a PS4 Controller. Not a slim. But it seems like my motherboard screw is on the other side.. its on the right side of the motherboard and my graffiti is on the left.. what controller do i need to fix this?
TheTechnoMan - 回复
使用镊子轻轻取下连接到主板的触摸板排线。 触摸板排线通过连接器连接到主板,该连接器需要翻转来松开。 在重新组装时,为了重新连接排线,塑料托盘需要从主板上轻轻取出,并且将翻盖锁翻开。 使用镊子轻轻取下连接到主板的触摸板排线。 触摸板排线通过连接器连接到主板,该连接器需要翻转来松开。 在重新组装时,为了重新连接排线,塑料托盘需要从主板上轻轻取出,并且将翻盖锁翻开。
  • 使用镊子轻轻取下连接到主板的触摸板排线。 触摸板排线通过连接器连接到主板,该连接器需要翻转来松开。 在重新组装时,为了重新连接排线,塑料托盘需要从主板上轻轻取出,并且将翻盖锁翻开。
Be very careful when you detach the touchpad ribbon. You could disconnect the other end that is inside the touchpad. In fact I would recommend you use a plastic spudger to release the clips on the sides of the battery holder, and then lift the latch to the ZIF socket of the touchpad. If your touchpad is not working upon reassembly, then the other end of the ribbon cable my have came loose in the touchpad. Use a plastic opening tool to remove the back of the touchpad, and lift the brown latch of the ZIF socket and reinsert.
Patrick - 回复
thanks for the advice
TMC -
currently doing this and have found the desoldering part the most difficult. i purchased a 40w solder on sale and attempted to remove with flux and wick to no avail. a buddy of mine tried with his station and no dice. at this point im thinking the contacts are lead? any advice?
swammieslippyslappy -
So the springs are annoying couldn't see were you talk about these as it's very fiddly to do the last step of putting it back together. Not just a reverse of taking it apart!
Frank Theplank - 回复
I concur. The springs are the worst part of this job. It would be nice if someone edited this to add some tricks for reassembly.
raysmalley -
You just have to put the r2/l2 buttons on the top side. There's a space around that white rubber thing where you can just snap them in. So that you have all the shoulder buttons together before putting the 2 parts back together.
Flow Von D -
Tilt your controller and trigger so the triggers are pointing to the ground it stops the spring popping out so much place spring inside the trigger and clip on thats how i do it anyway :) the touchpad is my problem area replaced my stick covers and now it just doesnt work at all :(
drwhatfunk -
Thank you for this recommendation. Made disassembly SO much smoother.
jeninholland02 - 回复
What I did for the Springs was place the spring on the button. Turned the button to where the spring is up on top then attached the button to the controller this helps keep the spring in place as you reattach it that is really the only trick that I found to it.
Matthew Luna - 回复
小心地从前盖拆下主板组件。 振动电机十分松动的与转相连。 在两端支撑,以便分离。
  • 小心地从前盖拆下主板组件。
    • 振动电机十分松动的与转相连。 在两端支撑,以便分离。
  • 当移除主板组件时,切勿将外壳上下倾倒,按键可能会掉出来。
添加评论
成功的拆解了控制器,将呈现以下三个部份。 主板组件 前外壳
  • 成功的拆解了控制器,将呈现以下三个部份。
    • 主板组件
    • 前外壳
    • 后外壳
One day my R2 trigger refused to work all in a sudden. The second day it spread to my square button. I dissembled the controller to this step and found some liquid between the green motherboard and the black plastic holding it. I should not have bought a second-hand especially for a launch version. Anyways I cleaned it up and it still didn't work. I then went to ebay and bought a new motherboard. Basically it is a piece of delicate plastic like PCB. It is held in place by 3 plastic columns and 3 gaps for sliding underneath both triggers and the touch pad. Sorry for no pictures but a careful removal of the old one would give you the best illustration of how to put the new one back. First remove the rubber pads of the triggers, which allows you to slide in the PCB. Then there are another 2 small plastic columns at the back of the gap near the touch pad. There is no need to detach the rotors. A pair of tweezers would help greatly. My controller now works perfectly like new and thanks to the author.
meaningless - 回复
使用“助手”或类似的工具来保持电路板稳定的焊接工作。 这些焊接连接将需要拆焊。由于电路板倒挂,左边是正确的方向 利用去焊芯和助焊剂来熔化并去除焊料
  • 使用“助手”或类似的工具来保持电路板稳定的焊接工作。
  • 这些焊接连接将需要拆焊。由于电路板倒挂,左边是正确的方向
  • 利用去焊芯和助焊剂来熔化并去除焊料
添加评论
一旦所有的触点被拆除,旧的操纵杆可以拿下来。 这可能需要一些练习,因为所有的焊料都必须去除。 在熔化焊料和使用灯芯的同时,在操纵杆上拉一点点也是有帮助的。 确保更换操纵杆的触点与原件相同。 检查所有的孔是否清除了旧的焊料。 可以使用注射器以及非常小的钻头来清除孔。 电路板上熔化的物质是用于脱焊的助焊剂。
  • 一旦所有的触点被拆除,旧的操纵杆可以拿下来。 这可能需要一些练习,因为所有的焊料都必须去除。 在熔化焊料和使用灯芯的同时,在操纵杆上拉一点点也是有帮助的。
  • 确保更换操纵杆的触点与原件相同。
  • 检查所有的孔是否清除了旧的焊料。 可以使用注射器以及非常小的钻头来清除孔。 电路板上熔化的物质是用于脱焊的助焊剂。
Hi Im haveing alot of trouble finding a reputable place to buy a replacement analog stick. Can anyone suggest a good place(that ships U.S) that sells a replacement of good quality?
taron C heath - 回复
将新的操纵杆插入电路板。 确保它正确就位,并且所有触点都与电路板上的孔对齐。 将所有触点焊接到电路板上。 这是维修过后的电路板。 剩下的就是用一些异丙醇清除旧的焊剂。
  • 将新的操纵杆插入电路板。 确保它正确就位,并且所有触点都与电路板上的孔对齐。
  • 将所有触点焊接到电路板上。
  • 这是维修过后的电路板。 剩下的就是用一些异丙醇清除旧的焊剂。
添加评论
结论
要重新组装您的设备,请按照指南并按照相反的顺序解决。
34等其他人完成本指南。
特别感谢这些译者︰
100%
大大大大大瓜砸正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
oldturkey03
于2010年09月29日注册
517,727 信誉积分
创作了120篇指南
团队
OTS OTS 的会员
Business
1 名成员
创作了120篇指南
Swammieslippyslappy, there is no lead in the device, if so the solder would release much easier. Lead Solder goes to liquid at 180-190 Celsius vs lead free at 212-226 Celsius. I would suggest buying a desoldering iron (cheap ones are fine $10-$20 they have the bulb attached for one handed operation) as using a solder wick becomes rather tedious with the smaller parts.
Joseph Van Meter - 回复
Would this fix the issue with the L3 button not remaining activated after initiating? (ie. running in call of duty)
Jorge - 回复
Very helpful guide!! I've never soldered/desoldered anything before so this was a little difficult for me. I ran into a few problems along the way: my inital soldering iron was 30W and it wasn't melting the solder, so I had to buy a 40W iron and that one did the trick. I also had a rough time using the desoldering wick (the solder didn't seem to suck up into the wick) so I ended up using a combination of a desoldering pump and the wick. I eventually got the piece out and the rest was easy! Thanks again and if anybody needs help with this project feel free to message me and I'll do the best I can to help.
SergeantCorbett - 回复
Hi SergeantCorbett,
I don't know if your offer still applies but I'm a soldering virgin and would appreciate any nuggets of wisdom you may have for me!
Thanks a lot
Jake
Jake Hogan -
I managed to carry out the stick replacement. Desoldering was definitely the most difficult part.
Whilst I was struggling with the desoldering I accidentally leant my iron on the ribbon connector to the right and managed to melt it. I can not put the ribbon in the connector now.
The joypad works fine but it wont charge now because I can not reconnect the ribbon.
If anyone can give any advice of the pin layout of the connector so I can get it to charge, I would be really grateful. Or if anyone knows where I can source a replacement mainboard I would consider that as an option.
Tony Morris - 回复
Hi tony,
Replacebase.co.uk do them
Cheers Jake
Jake Hogan -
i did all this. had to use a solder pump and a soldering iron to remove the solder, coulding do it with just wick. put everything back together and everything is working now, except my L1 button? I just changed the Left analog. not sure what i did to futz up the L1. been searching the internets and have yet to find what to look for on this.
Albert Schroter - 回复
Are you sure the controller will work after that? I'm going to be replacing that thing on my dads 2 controllers and That part of the motherboard that had to be desoldered looks super boiled, burnt and 100% broken. Whoever answers this you need to be 110% sure that the controller will still work after that
jwilson12380 - 回复
I should work . The reason it looks burnt is because they probably didn't use water soluble flux. So without the proper solvent chemicals, it left a gross brown residue. It's not actually burnt, just has a gross layer of flux that hasn't be cleaned off.
Connor Crothers -
I had a feeling that this is what I was gonna have to do haha. Thanks for confirming that it would work!
Rylan Lujan - 回复
Hi i have 1 problem. .. i changed my left stick, he's working but when i playing games automatically character walking to the left side... what is the problem i bought sticks from aliexpress and i got 2 sticks, so i tryed both of them... and still same problem.
Marius - 回复
I bought 2 sticks from ebay(seller: oo_875, ). the seller is related with the first comment ebay seller(you can find that clue from their review comment).
they are selling MALFUNCTION products. I think It is a same problem that Marius mentioned (the previous comment writer).
and I think a 40w soldering tool is not enough for desoldering that(took so long)
So, I failed.
Be careful on buying stuff and good luck to you.
yeonminpark - 回复
I had a problem with unmelting solder before. Fixed by sanding and tining the soldering iron.
Laser Bean -
How many watts do you need for soldering iron? 30,40,60?
Dengo - 回复
@dengo all the work was done with an inexpensive 30W soldering iron.
oldturkey03 -
Could the heat of the soldering iron damage the joysticks?
Laser Bean - 回复
Laser Bean only if you burn the components or traces…….
oldturkey03 -
I did this and now my joystick and my d-pad will go down when pushed but right as I let go it moves up on it's on. Any ideas as to what went wrong?
Chris - 回复
添加评论
浏览统计数据:
过去的24小时: 72
过去的7天: 549
过去的30天: 2,577
总计 120,932
