简介
In this guide, you will be instructed on how to adjust and synchronize the output of the two carburetors.
Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner. Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
  • Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
  • Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
  • Start the engine
添加评论
Allow time for the engine to warm up completely Attach carburetor synchronization tool to  one of the carburetors
  • Allow time for the engine to warm up completely
  • Attach carburetor synchronization tool to one of the carburetors
  • Observe the relative reading, and remember it.
    • This reading is a measurement of the airflow speed
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
Set the  synchronization device on the other carburetor.
  • Set the synchronization device on the other carburetor.
  • Using a Flathead screw-driver, twist the idle speed screw in to raise the flow, and out to lower it.
  • Recheck both carburetors and adjust as needed to get the flow as equal as possible.
添加评论
Now, the idle mixture screws must be adjusted. It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
  • Now, the idle mixture screws must be adjusted.
    • It is important that when the screws are adjusted they are adjusted the same amount in the same direction.
  • Turn both screws in, or out an 1/8 or a turn at a time until the fastest idle speed is achieved.
    • Before proceeding with this step you should have already checked your ignition timing, if you have not do it now, and then continue from here.
添加评论
Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
  • Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
    • Once more, it is important to adjust the screws the same amount.
  • Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
hao ,jiu shi zhe yang
wangjiaobyd - 回复
结论
Congratulations, your Corvair should now idle properly. If the Carburetors are still not operating properly, then the linkage is not synchronized, or they are in need of repair or rebuild. (A linkage adjustment and rebuild guide will be made soon!)
18等其他人完成本指南。
Noah
于2012年10月03日注册
406 信誉积分
创作了6篇指南
团队
Cal Poly, Team 6-33, Regan Fall 2012 Cal Poly, Team 6-33, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G33
3 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 16
过去的7天: 114
过去的30天: 627
总计 33,178
