简介
We took apart the Kindle Paperwhite 3 (7th Generation) to find a simple constructions. The Paperwhite 3 comprises a e-ink screen, replaceable battery, and a single motherboard, earning it a respectable 8 out of 10 for repairability.
Front and rear reference shot.
  • Front and rear reference shot.
添加评论
Adhesive is holding the bezel in place.
  • Adhesive is holding the bezel in place.
  • An opening pick and an iFixit opening tool were the only tools needed to remove the bezel.
  • No heat was needed, yielding a moderately difficult opening procedure.
添加评论
  • There are 11 Phillips screws holding the midframe to the rear case. One of those screws is hidden underneath tape.
  • Once the screws are out the midframe easily separates from the rear case.
  • The battery and motherboard are connected to the rear case.
添加评论
  • Battery is held in place by three Phillips screws.
  • Once the screws are removed, the battery can be removed by lifting from the bottom.
添加评论
  • The motherboard is held in by 5 Phillips screws.
  • There are 3 ZIF connectors and 1 press connector that must be disconnected before removing the motherboard.
添加评论
  • The Amazon Kindle Paperwhite earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
    • The battery was very easy to remove.
    • All screws were Phillips #00 screws.
    • All components likely needing replacement were modular, except for the USB port.
    • Thin layer of adhesive that needed to broken in order to remove the bezel and access the internal components.
    • Manufacturer does not provide user-accessible repair documentation.
添加评论
终点
5等其他人完成本指南。
Evan Noronha
于2015年02月05日注册
134,899 信誉积分
创作了728篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了6,201篇指南
Thanks! Looking to replace scratched screen and this gives me confidence to diy.
Ricardo Birnbaum - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 33
过去的30天: 169
总计 2,348
