简介
We dismantled the Acer Iconia One 7 and found it to be extremely repairable with only 8 components.
Reference photos with packaging. Reference photos with packaging. Reference photos with packaging.
  • Reference photos with packaging.
添加评论
Entry method is to remove the rear bathtub case, the seal is easy to break with opening tools.
  • Entry method is to remove the rear bathtub case, the seal is easy to break with opening tools.
    • The bathtub case is attached to the front display panel by soft plastic clips and without adhesive.
  • A spring connector connects the motherboard to the bathtub case so no need to worry about damaging fragile cables during removal.
添加评论
The battery cable runs short and requires a careful and precise wiggle to remove its connection from the motherboard. Only two adhesive pull tabs secure the battery. This is preferred over adhesive which requires heat and prying to separate. The adhesive strips will need to be replaced after removal.
  • The battery cable runs short and requires a careful and precise wiggle to remove its connection from the motherboard.
  • Only two adhesive pull tabs secure the battery. This is preferred over adhesive which requires heat and prying to separate.
  • The adhesive strips will need to be replaced after removal.
添加评论
Layer of components removable upon opening: power/volume button cable, loudspeaker.
  • Layer of components removable upon opening: power/volume button cable, loudspeaker.
  • The power/volume button cable is lightly secured with adhesive.
  • Two Phillips #0 screws secure the loudspeaker housing.
添加评论
The display, digitizer, and camera cables can be disconnected without removing the motherboard. The motherboard is secured to the display frame by three Phillips #0 screws.
  • The display, digitizer, and camera cables can be disconnected without removing the motherboard.
  • The motherboard is secured to the display frame by three Phillips #0 screws.
  • The Micro-USB port, headphone jack and microphone are soldered to the motherboard. These are common failure points and it would be better if they could be individually replaced.
  • The front and rear camera are tethered and will need to be replaced together if one where to fail.
添加评论
Motherboard reference photos. Motherboard reference photos.
  • Motherboard reference photos.
添加评论
The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool. The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool.
  • The digitizer is fused to the front case but the LCD display can be isolated by unclipping it from the assembly with an opening tool.
添加评论
The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair): LCD and front glass are not fused and can be replaced individually.
  • The Acer Iconia One 7 earns an 8 out of 10 on our repairability scale (10 is the easiest to repair):
    • LCD and front glass are not fused and can be replaced individually.
    • Battery is easy to replace.
    • Modular design allows replacement of many individual parts.
    • Standard Phillips screws used throughout.
    • High wear components soldered in place, which increases replacement costs.
    • Manufacturer does not provide user-accessible repair documentation.
添加评论
终点
2等其他人完成本指南。
Blake Klein
于2017年01月29日注册
31,395 信誉积分
创作了21篇指南
团队
iFixit iFixit 的会员
Community
109 名成员
创作了6,182篇指南
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 20
过去的30天: 74
总计 1,149
