The Frontier was introduced in 1997 for the 1998 model year as a replacement for the aging 1986.5–1997 Nissan Hardbody Truck.
2 个问题 查看全部
My AC unit runs hot air for half an hour before cold air comes out,.
My 2001 Frontier AC unit runs hot air for half an hour before cold air comes out, and when it does the pressure is good too.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
@nassaubay
could be a bad compressor etc. Start off with making sure you have enough refrigerant.
With AC’s it is hard to make a determination since it requires the proper gauges and testing equipment to do so. Consider having it checked (diagnosed)by a AC shop.
Here are some ideas for the basic testing
If you want to go all out, this will definitely help you if you can get the tools. Frontier-HVAC.pdf
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Boris Berezin 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 11
