这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4315 个问题 查看全部
My iPhone 6 is stuck in a BootLoop
My battery charger indicator wouldn't move past 6% so I decided to replace the charging port. After successfully inserting the new charging port, I powered up the device and found that i was stuck in a boot loop. I immediately tried a hard reset and then restored the device. I even unplugged the battery and re plugged it back in. I know its not the battery because the battery is brand new. Maybe i was too rough with the charging port when aligning everything but i felt that i was pretty careful: So my question is what would have caused the phone to enter a bootloop because it can't be software related. (I know it worked before replacing the charging port) I'm pretty sure I'm going to try replacing the charging port again but i don't want to wait for a new charging port and then the problem not be the charging port.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
已选择的解决方案
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
Replacement "small parts", such as flexes and charge ports tend to have a high failure rate. When replacing a small part doesn't solve your problem, you should always consider trying another one. When possible, getting access to a known-good part (for example, from a working device) is the best solution. In the case of flexes that have multiple functions, such as the Lightning port, try putting the original one back to see if you resolve the new problem. that would indicate a defective part.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
lockon916 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 127
