The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1470 个问题 查看全部
Does iPhone 5c need glue
I have an iPhone 5c and was wondering if I can just use superglue around the edges of the top glass of the phone instead of using the special glue all over
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
2个回答
no it doesnt it uses screws
这个答案有帮助吗?
按维修分数 0
添加一条评论
I'm assuming you're talking about replacing the glass screen, and then just glueing it to the frame instead of using LOCA glue over the LCD. Technically, yes you can do this, but it will not look good or be as responsive as it should, and I would definitely not recommend it.
Either buy the full assembly with LCD attached, or take it to a professional. You will be much happier with it.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
ajg2cool 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 73
