The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
266 个问题 查看全部
water damage Samsung galaxy note 3
Please help I drop my Samsung galaxy note 3 in the toilet I take the battery out and put it in rice....it turns on but the screen is black? Please help!?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 5
评论:
i have the same problem but the phone work by the s pen only
添加一条评论
2个回答
最有帮助的答案
phylicia sifuentes, safe the rice for some cooking. It does no good in electronic repair. It is a big myth and is equivalent to doing absolutely nothing. Remove the battery and do not try to charge or to use your phone. It is time to disassemble your Note. Use this teardown as an idea of what is involved. Once you have it open, clean everything with high grade (90%+) isopropyl alcohol and a soft brush to clean every part of your phone. Clean the connectors on the board as well as on the cables. Once you have it properly cleaned, replace the battery then re-evaluate. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 2
评论:
Thank you soooo much for the helpful advice!!!! After a day of panic and a completely black screen, I'm happy to say my Note 3 is functioning once again. Day 1- I used both the rice and cool air method. Day 2- I submerged my motherboard in 91% Isopropyl Rubbing Alcohol for 15 minutes following a helpful YouTube video... This forum is a pure lifesaver!!!
添加一条评论
此回答最初是针对另一个问题
without more information its hard to say, but heres some general suggestions, pull the battery, there is likely still water or corrosion inside witch may cause more damage with power going through the circuit, if your conformable with it i suggest taking the phone apart and cleaning the board with isopropyl alcohol.
这个答案有帮助吗?
按维修分数 1
评论:
I don't know how to take it apart! Could I just put the whole thing in isopropyl alcohol..?
there are guides on this website, but i would not suggest puting the whole thing in alcohol, it could ruin the display, and thats the most expensive part for that phone.
添加一条评论
添加你的答案
phylicia sifuentes 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 21
过去的30天: 84
总计 16,772
